delete auto-peering
delete auto-peering
Description
This command deletes auto-peering (either OSPF or BGP), removing all of the auto-peering configuration. This command deletes the VLAN list, loopback, and BGP configuration created with enabling auto-peering.
Syntax Description
Default
N/A
Usage Guidelines
Important
Important
Deleting auto-peering when executed on a large leaf-spine topology causes massive change in the network with many route withdrawals and updates.
The following example deletes auto-peering:
# delete auto-peering
This command was first available in ExtremeXOS 22.5.
Ability to delete OSPFv2 Auto-peering was added in ExtremeXOS 30.6.
Platform Availability
This feature requires the Advanced Edge license. For more information about licenses, see the Switch Engine v33.1.1 Licensing Guide .
